PLC master and MODBUS RTU
sandhya61280
Oct 2008
Mumbai
I would like to know what data structures (MODBUS RTU protocol) do the popular Masters such as PLCs or SCADA support. We intend to decide a slave unit that can be interfaced with another PLC or SCADA and want to use MODBUS RTU protocol. We are confused about the data structures since we want to operate on floating point numbers as well and do not know whether all masters support this format.
Sandhya
It may be helpful if you tell us what your slave and masters are, for floating point most masters just read 2 registers then you declare the data type as Floating in your SCADA or HMI, not much more too it than that really.
If you download a few of the OPC Servers out there you will see be able to see what they support. These manufacturers are going to support what the industry is expoecting. Yolu will find some specialt flow meters that use and Enron Modbus Format. If your device is targeted for the Petroleum or Water Management Markets you will wnat to use this format.
Hi guys, Just wondering if anyone has tackled an issue similar to this before: creating a redundant master on Modbus so I can have a redundant...
464
I'm using a Automationdirect CLick PLC (c0-02dd2-d). It has 2 RJ12 ports and 1 designated RS485 (we will call this port 3) port. My thought...
3,199
I have downloaded Modbus Poll software ,so I can siulate SERVER and client. In my example Server is PC with IP - 192.168.0.17 SLAVe is PLC...
3,516
We are looking into purchasing a modicon momentum PLC that will control a slave using Modbus TCP over Ethernet. We would like to also export...
4,380
I have a Schneider M340 PLC with a modbus processor BMXP342000 and a ethernet NOE110 card. The modbus port is used as Master to communicate with...
6,069
