PLC multipoint using Lantronix 1100 UDS
vrclan
Nov 2006
California
Hi, I don't know if this is a bit off topic or what, but I'm really stumped and figured this would be a good place to check for an answer.
I'm trying to get PLC multipoint communication, basically having a "master" PLC talking to two "slaves" over a radio connection. The configuration is set up as PLC to Lantronix UDS 1100 (for serial to ethernet conversion) to Radio, on all ends.
I had a previous configuration like this, but only point to point, and it worked fine.
The problem is with the UDS 1100, it seems to require that I give it one "endpoint" IP to talk to, regardless of whether I use UDP or TCP settings, which in short means I can only get point to point. Ex 192.168.0.1 talks to 192.168.0.2 and vica versa, with no option of directing the UDS to multiple IPs.
Can anyone help me set up the multipoint configuration, or direct me to a better place on which to search for help on this device?
Your help is much appreciated.
Hi all, looking to model old RR relays in PLC. Does anyone have any SPECIFIC examples on how to model a relay such as a polar relay, slow pickup...
79
HelloI need software to download the program from PLC EH-A28DRP from an old machine whose manufacturer does not exist. It may be Ladder Editor for...
69
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
284
Hello, I have a Mitsubishi FX3G 14M PLC and a E615 HMI from Mitsubishi/Beijer. I'm using GXWorks 2 to do the programming and I have no problem...
147
Hi, I'm trying to import a Rockwell/AB EDS to Beckhoff but I'm not sure how to import/install the EDS. It is a PowerFlex 525 EDS. Is there a way...
107
