PLC Panel design/build
cornbread
Feb 2007
madison, indiana
407
Looking for a good panel designer/builder that can turn around a project quickly. Panel will be AB Control logix and associated part and pieces, any help greatly appreciated.
Call PACIV in Indianapolis (317.423.8819). I've had them build several enclosures for me over the years and I remain impressed with their workmanship, capabilities, and professionalism.
FYI - aside from being a repeat customer, I have no affiliation with PACIV.
Steve
I've had some good results with
Panelshop
Panelshop.com, LLC.
1100 Rico Road | Monroeville, PA 15146
If I need a shop in the future I'll probably hit them up first, only downside is they're across the country from me.
Id like to put a quote in for it. I can send you some pics of a huge controllogix panel I just completed.
OK shameless plug for my shop. I'm just outside of Louisville Ky. Not to far from you ,from what I recall.
Dears ALL I am preparing new PLC panel I want from the contractor to make redundant CPU , power supply and I/O modules, the contractor refuse to...
3,106
Hello, I am a plc engineer and I have a job to do in the NIGERIA 25000 TON GRAIN SILOS STORAGE CONTROL PANEL. A problem where the panel is not...
116
Can I connect two A-B Panel View 7 to a A-B PLC. Same graphics etc. One on the local control panel and the other Panel View 7 in a remote control...
63
Hi, These is an already working plant with HIMA PLC that has a Siemens Comfort Panel HMI connected via Ethernet. HIMA is type 51QHS. I want to...
293
Our a customer has got S5-95U Plc and OP17 Hmi.OP17 is defect.They want to use a new generation Siemens Simatic basic panel (KTP400,700,1200...
2,009
