PLC - Power Supply
It will work but it is generally it is not a good idea as if you lose power to your plc you lose alarming and visibility of your process. I like to ensure my plc always has power so I know what is going.
Ideally all your devices should go to failsafe position on loss of signal but this is not always the case depending on your setup you may have motors that keep running or valves that stick open.
As long as you know the risk and don't let it linger it can get you through
a short time ago I was talking with somebody that they had a 24V power supply in a major system panel go out. The replacement was days away they needed to run. so they connected the 24VDC to a tow motor battery
It got them by until the new power supply was installed.
This is one of the reasons I make critical systems operate on DC wherever possible. Much easier to do redundancy with DC. I feed one DC supply from UPS and one from mains. If one is lost you have the other.
Just beware if you were using the UPS as a surge and line filter, you may have removed these protections too. So a separate surge and line filter may be a nice to have...
Hello Everyone, I have in an electrical panel a simple 220VAC to 24VDC power supply (as shown on the picture bellow) can this type of power...
1,361
I have a remote PLC (Micro800) that is doing some temperature monitoring and reporting on hourly intervals via ModbusTCP to our DCS. It will be...
767
Dear All, Currently I'm working for PICO Hydro system that installed at remote rural area which there have no power supply from service...
1,482
Hi, I'm challenging myself to install a PLC for the first time. I went for a Micro830 48QWB, since it has 48 I/O and free software (CCW). From my...
1,980
I am trying to get a more intimate understanding of hardware requirements when setting up a PLC Program that utilizes multiple cards. I was told...
1,786
