PLC programming style??
just remember who is going to maintain the machine, maintenance. keep the programming straight forward so that they can understand the logic. ask them what they are used to and how they would do it.
REMEMBER!!!!!
if maintenance can't understand the logic, the machine won't get fixed, production suffers, your boss gets yelled at and you in turn not only get yelled at, but baby sit the machine 24/7 or until you rewrite the code so maintenance can fix the problems. by that time,,,, I think you get the picture.
regards,
james
From a maintenance person - GREAT ADVICE. Last year our department spent $50 000 getting one of our programs completely re-written, because it was such a disaster that even our own engineers couldn't follow it. Nothing worse than trying to fault find an incomprehensible program on a broken machine at 3 in the morning.
Like others have suggested, he probably meant state machine, not statement list. Who would demand a program to be written in statement list ?
I use state machines for some of my programs. All the work is to define the state diagram. Pen and paper is used to make the 1st sketch, and then you continue to work on it until you have all situations covered.
When you think you have the state diagram nailed down, scan it and store the electronic copy together with the PLC program (!).
As to troubleshooting a PLC program based on state machine, then the printed state diagram is absolutely necessary. A PLC program based on state machine is very strucured, but may be confusing to look into by just looking at the code. This because the logic is split into states and transitions.
The HMI should indicate to the operator what state the sequence is in, and what conditions are required to transition to the next state (there may be several possible next states). This part may take a bit of work but is worth it. It may help to that the operator himself can figure out what is wrong without the need for a programmer to come.
After reading all of these posts, does anyone have any examples they can share of a state diagram and corresponding plc logic?
Hi, I am trying to set up a plc. I've never done any programming with ladder logic previously. I'm trying to set up a a program to turn a device...
261
Hello colleagues, Some time ago I started my adventure with programming. With your help and the courses, things are starting to come together...
771
Dear All, I need a sample PLC program to count the output pulse of a mass flow meter so that a specific amount of mass (for example 100gm)can be...
182
Hi Please I have zeilo smart relay #SR2A201BD but I don't have it's programming cable. Can I use any general usb/rs232 converter? Or need...
190
Hi, Does anyone have thoughts or know of, can point in the right direction any published materials with a plumbing centric point of you explaining...
194
