PLC Programming
As far as I'm aware, this isn't possible unless you implemented a switch that people could push everytime they've done an upload? I don't think there's an automated way of doing this...?
Unless uploading would adversely affect the scan time and there was some way of monitoring fluctuations in scan time perhaps??
Do you mean "Downloading" - As in transferring a new program to the PLC ?
If this is Logix5000 (1756 ControlLogix/GuardLogix, 1768 CompactLogix/CompactGuardLogix, 1769 Compactlogix, 1789 SoftLogix, or DriveLogix) you are talking about, then yes, there is a way, using "Controller Logging" to CompactFlash memory card.
Get hold of Publication 1756-PM015C-EN-P and look at chapter 3.
If it is anything other than those above, I'm afraid I don't know.
Again, not sure about uploading, but for downloading. For many PLCs, when you download a PLC program, the PLC leaves run mode during the download. Most PLCs have a "first scan" program or bit that executes or is set on the first scan of a program after leaving stop mode.
You could hook a counter up to the first scan program or bit.
Which of course will count every transition into run-mode, including any power outages, deliberate or not.
Hi, I am trying to set up a plc. I've never done any programming with ladder logic previously. I'm trying to set up a a program to turn a device...
238
Hello colleagues, Some time ago I started my adventure with programming. With your help and the courses, things are starting to come together...
713
Dear All, I need a sample PLC program to count the output pulse of a mass flow meter so that a specific amount of mass (for example 100gm)can be...
169
Hi Please I have zeilo smart relay #SR2A201BD but I don't have it's programming cable. Can I use any general usb/rs232 converter? Or need...
179
Hi, Does anyone have thoughts or know of, can point in the right direction any published materials with a plumbing centric point of you explaining...
180
