PLC pulse generator
tibko79
Jun 2005
Hello
Is there any possibility to generate pulse with frequency higher than 1 kHz (time period less than 1ms) using S-300 ? Maybe it is possible using some SFC's.
Is it possible also read so high frequency signal ? ( from example signal from incremental counter of electric drive ). Thanks
tibko79 said:
Hello
This link is to the spec sheets for S7-300 standard models. The simple answer to your question is yes. Some models have integrated functions that can read incremental encoders up to 60KHZ and pulse output at 2.5KHZ.
http://automation.usa.siemens.com/autogen/docs/plc/s73/dl/S7-300_CPU_specs.pdf
Pusle Generator on S7-300
There is a FM 353 Positioning Module 6ES7 353-1AH01-0AE0 that you can use although is is primarily for Stepper positioning and can be tough to implement. A better solution if you have profibus or can use an ET200S CPU is a pulse output module designed for the ET200S line. Its part number is 6ES7 138-4DD00-0AB0. This is by far easier to configure. It will require you to add an ET200S Drop on profibus or use a ET200S CPU with this item in the rack.
I have PLC Omron CJ2M with OD211 module. I want to use the pulse output and PWM output and this module. But i confuse how to activated this, i...
125
hi everyone ,im currently programming in fatek plc ,when i use fun140 function block for serov motor the motor is working but when using fun141...
898
Hello all, I am working with a variety of discrete pulse flow meters, Siemens, Flomec, and Seametrics. I am attempting to read flow via discrete...
17
4,786
Hey guys, I am building a small prototype for a Coolant Dispensing System and need to measure the flow rate of water & chemical in the pipe in...
3,692
Hi I want to calculate the time duration of a high pulse in milliseconds in ST language.It would be very helpful if I get the proper suggestion...
4,890
