PLC questions
nautica03
Jun 2005
Electronic programming gurus...
Given two single - pole switches, write a program that will turn on an output when both switch A and switch B are closed?
Given two single - pole switches, wirte a program that will turn on output when either switch A or switch B is closed?
Given four NO (Normally Open) pushbuttons (A-B-C-D), write a program that will turn a lamp on if pushbuttons A and B or C and D are closed.
I seem to be stuck. Help would be greatful.
I'm new to this. Basically i was given a book called PLC and from reading chapter one it doesn't say anything about switches. all it provided was info on what are PLC .. so when doing the question 1. It doesn't make no sense. i'm new, it's like learning a new language with no where to start at. :|
wow thanks you guys. I got it. It consist of and or gates. ^___^
student at itt-technicial institute of technology majoring in CEET .. computer electronic engineering technology. ^____^
A B output
This is an AND..A and B...if A and B are TRUE then turn on ouptut.
A ouptut
| B |
This is an OR...if A or B is TRUE then turn on output.
For the above outputs to stay on the inputs must stay on.
This is not defined properly, are the pushbuttons maintained or momentary?
Who cares what the external inputs are (maintained or momentary). The logic is the same for the question as written. Now if it had been written as "A THEN B or C THEN D" then it might be time to question.
You are probably right, all these are simplistic so its just A and B and C and D is true then turn on output.
I think I read more into because the original questions stated "switches" and this one did not. That left it open to a few things...ie WHO HAS 4 HANDS?
Using bernies asessment and the 4 pushbuttons are momentary then you have to keep them pushed down for the output to stay on. If they are maintained then you just have to push once to latch them into the maintained position.
A B C D output
Good Grief...
Switches A & B...
A B
--| |-----| |------( ) Output
A
--| |--+-----------( ) Output
B |
Push Buttons, A, B, C and D...
Turn Off
Output
A (N/C)
--| |--+---| |-----( ) Output
B |
C |
D |
Output |
--| |--+ <-- This is a Latch until Turn Off Output is pressed
Geez...
That is why I didnt think it was defined properly.
He stated A B OR C D are closed...wasnt sure how he actually meant it but had an old age moment after bernie's reply.
TECHNICALLY:
A B output
| A B |
If the buttons are maintained, if not then add:
output
OR take your pick...
BUT
If momentary how do you turn the output off?
boolean expression
hi all,
i am redzuan from malaysia and beginner to learn PLCs. can u help me to settle this problem?
the question is:-
write the Boolean expression and draw the gate logic diagram and typical PLC ladder logic diagram for a control system wherein a fan is to run only when all of the following conditions are met:
*input A is off
*input B is On or input C is On, or both B and C are on
*inputs D and E are both On
*One or more of inputs F,G or H are On.
hope u all can help me.
thanks,
redzuan.
Hello All, Was hoping I could get a little help with Modicon ladder logic. This is the first time I have seen Modicon logic and currently trying...
297
I have never dealt with an Eaton PLC before. I have a customer that has a piece of equipment with an Eaton PLC (XNE_GWBR-CANOPEN). I don't have...
2,304
HI, im a student and never experience changing PLC battery. i have some questions in mind. 1. how will i know if the battery is low or it...
3,058
Describe how you would perform a 2-point linear calibration of a PLC analog input? The scaling is calculated in PLC ladder.
4,838
Describe how you would perform a 2-point linear calibration of a PLC analog input? The scaling is calculated in PLC ladder. While tuning a...
4,478
