plc rungs tags are fading when scrolling using mouse!
pssriram16
May 2006
San Francisco Bay Area
39
When I scroll up or down on a ladder logic using mouse, some of the tags just fade away or disappear..never had this problem...is it the laptop or the resolution??
Even after I click on those tags, they still dont appear....I have use the keyboard UP & DOWN keys to get the tags display and re-appear right.
Sri
Wiggle your vga cord.
Just joking...seriously, did this just suddenly start happening after working normally? I have seen graphics goof-ups in RSLogix500 before very similar to that, but it has never been permanent. Restarting Logix or closing and re-opening the ladder window fixed it in my case.
You might search the knowbase at ab.com
Paul
this laptop was given to me a week ago. Ever since I have been working with it I have been having this problem. Even after restarting the ladder logic code, the probelm does not go away...this is weird.
I have never had this issue with any other PC or laptop before.
Sri
Do you have a support contract with Rockwell Automation? If so, you should call them to start a new case and send them your screenshots. I searched the knowledgebasebase and only found only one article that described something similar but it was for FBD and ST diagrams, not ladder.
Hmmm.
The one knowbase article was in reference to version 11. They said to go into windows control panel, regional and language settings, and turn off any language settings you don't need.
I wonder if that will help in your case?
Paul
I seem to remember having this problem with my last laptop. If I recall I had to install a mouse app called freewheel or flywheel or something like that.
Good Morning , I should know this . I would like to import some rungs into a running ControlLogix PLC . Can you actually keep a...
1,631
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
41
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
80
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
67
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
52
