plc scl 5 02 and pv 600
valife
Nov 2014
peru
I'm doing a good plc scl 17147 May 02 with ica pic eun have communicated mediate Cable rs232 to RsLink and I have a 600 connected via ethernet pv , the two both pv plc as I see in rslinx would like to make the link to the panebuilder 32
If you mean SLC5/02 then it supports DH485 protocol not Ethernet.
Please provide the complete catalog number of your PanelView.
Your PV supports Ethernet protocol. If you have a SLC5/02 it supports DH485 protocol only. You would need at DH485 to Ethernet converter, $$$.
Hopefully you have not connected the PV to the SLC5/02's DH485 port, as it may damage the PV's Ethernet port.
It is not clear that you have a SLC5/02. Can you clarify that?
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
101
I'm newbie in PLC and I face couple problem in SCL(194) instruction. The problem have wrote to the pictures kindly tutorial me how to do it...
10,704
Hello. I'm pretty new to PLC things, come from a C etc. programming background. Found this nice thread here...
26
11,940
Hey guys, I am bussy with programming an alarm that sends a sms with a gsm-modem and a Siemens plc s7-300. I need to program it in s7 scl. I...
2,889
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
161
