Plc selection
raulconnected
May 2010
bangalore
Dear friends,
among the plcs offered by ab, mitsibishi and siemens, which one offers more flexibility and got the best programming software..
I have heard that for some brands of plc's you cant program it from any system. Is it true?
Communication options wise which plc is d best?
Pls do reply
with luv
raul
mitsubishi is a gud option for the communication issue. but siemens programming software is the best among all these.
I recommend you logix 5000 series of PLC. I didn't use before Mitsubishi but I well know Siemens and AB. But main objective shoud be your requirements. You decide as your needs like flexibility, price, easy programming, command profile, communication capabilities and possible futur enlargement needs.
I think Siemens are best, I certainly dont like AB.
But check out Vipa, you can use the same programming-software as Siemes, but PLC from Vipa are cheaper and much much faster.
Vipa is also made in Germany.
I dont understand why npt many people use this!
Dear Members; We are going to design a Simplex Control System With Following: 1. 24 Digital Inputs (SIL 2) 2. 24 Digital Outputs (SIL 2) 3. 4...
1,146
Hello, Not able to find Modicon DO modules BMXDDO3202 in EcoStructure Control expert V15 catalogue. But i can find only MBXDDO3202K. Can you...
488
Good morning all, We want to build a test panel with IO link to get familiar with the product line. We have ML100's and SLC 5/03's currently...
1,632
Hi,I need to build a PLC panel with a CUP & I/O cards, the panel to be communicated with a remote (500 meter away) extension module station. I...
2,565
Hi All, EDS file is available for the device profile with the following assembly instances and max size (based on parameters in the respective...
2,995
