PLC small project problems
wolves-32
Feb 2013
VA
Hi everybody. I have taken class in PLC last summer. I diced that I am going to do a small project to understand plc more and how other devices can interfere with the plc
My project detail is :
it is a one level parking lot with 5 parking space ( small scale project)
* 2 inputs ( sensors for entering and exiting)
* 2 outputs ( gate for entering and exiting)
* 1/2 output(s) ( for the display : number of empty spaces and full sign. up/down display)
My problem are : 1. what is a cheap PLC that cover the details ?
2. How I chose display and let it interfere with plc ? (some ideas?)
3. where I can find small gates like the one in the real parking lots( l---- )
Please If you have any ideas let me know
Hello,
I don't know about gates, but for a cheap PLC and display look at the click PLC's and c-more micro series HMI from automation direct.
Hope this helps,
Dave
From my standpoint as someone learning PLCs for personal home-automation projects, I strongly agree with Dave's recommendation of the Click.
As for miniature gates, maybe someone makes them for model railroad layouts?
1. What is a cheap PLC that cover the details ?
Link to Automation Direct CLICK PLC:
http://www.automationdirect.com/adc...lers/CLICK_Series_PLCs_(Stackable_Micro_Brick)
2. How I chose display and let it interface with plc ? (some ideas?)
Choose one that will connect to and work with your PLC. Link to a C-More Operator panel that will connect to the CLICK:
http://www.automationdirect.com/adc...-Graphic_Panels/3_inch_Panels_-a-_Accessories
3. Where I can find small gates like the one in the real parking lots?
Link to Model Railroad Crossing Gates, which should do the job:
http://www.hobbylinc.com/cgi-bin/s8.cgi?cat_s=UF&tag0_i=807
Hi! I'm wondering if PLCs are used for small-scale production. I've got four machines doing different things with textiles, and I'm exploring the...
1,356
Hi all, I am looking to replace an old set of trip amps that used a complex thermocouple setup that did averaging electrically. I will run back...
3,018
I have a customer that wants to print data anytime someone presses a button for a batch addition. They want to print quantities, person's name...
3,033
Talking 7 to 30 bbl in size. Heavy on the temp inputs, lets start with 20, a few analog outputs and inputs, some digital IO, all expandable...
77
17,254
Ive done so much research that my head hurts. Im looking for a PLC that can meet the following criteria : Runs on 12 or 24 VDC. Has 2 or 3...
28
6,757
