PLC Timer Basics Question
Fafnir
Feb 2009
VA
Hey everyone, I'm a new user here and new to PLCs . I'm trying to teach myself PLC programming and have run into a snag using counters. I am using an old SLC 100 and am trying to program 3 different lights to come on at different intervals. Here's how it is layed out. I need someone to give me a sampe ladder to go by if possible. I'm getting this out of an old programming manual, but there is no answer key.
1st light is off for 8 sec. and then on for 8 sec.
2nd light is off for 4 sec. and then on for 4 sec. for 16 seconds.
3rd light is off for 2 sec and then on for 2 sec. for a total of 16 seconds.
Also, I would like this to reset itself and continuously run.
Any help? I'm lost.....Thanks a bunch.....
Hello Fafnir, and welcome to the forum. First, do you have the actual SLC100 controller, software and interface module in order to actually test your solution?
If not, you may want ton investigate learning on another platform, perhaps even an online simulator.
If you do have everything you need, I think I can provide some examples.
Paul
I just noticed that I said I was having problems with counters, but I'm having problems with TIMERS--Duh......thanks
See if this manual is the same as what you have:
http://literature.rockwellautomation.com/idc/groups/literature/documents/um/1745-um001_-en-p.pdf
It talks about timers in chapter 6.
All timers in a SLC100/150 are retentive. This means that they hold their accumulated values even when the timer rung goes false. The accumulated value will increase only while the rung is true, and freeze its present value when the rung goes false or even when the PLC is power cycled. Use the RST (reset) instruction to reset the timer when it is done, or when you need it to start over according to the needs of your program.
Also read through to page 6-4. On that page there is a pretty good explanation with examples and a timing diagram.
Paul
Hi, I am attempting to turn on an output for one second, every thirty seconds, but am having some trouble. I have a XIC with S:1/15 (first pass)...
615
Hi! i'm just wondering did there is any chance to change Set Time(TV) on Siemens plc timer without step 7 using c# or python if timer not set in...
1,263
Hi there I'm guessing this is a straightforward one but after much experimenting I've been unable to find an answer. The software is TIA V16...
2,372
Our old Omron X20K PLC has the following ladder timer code. TIM 000 #0030 Is this 30 seconds, or 3 seconds? or 0.3 seconds?
1,068
Hello how to move a new value to a timer preset PT, if possible? which of the timer parameter is , the timer current value? thanks
2,072
