Plc to Laser system Interface ??
Martin IRL
Jan 2003
Ireland
25
Hi All,
I have to interface a PLC control system to a laser system, the laser system has the ability to store 256 system settings (laser power, frequency etc) and these settings can be called/activated by applying a 24V signals to an 8pin connector. My question is I have 8 pins on the user interface of the laser labels as follows:
LOWER 1 UPPER 1
LOWER 2 UPPER 2
LOWER 3 UPPER 3
LOWER 4 UPPER 4
How do I find out what sequence of 24V at the pin of the connector equates to the 0 to 255 programs?
Many Thanks
Martin… :confused:
Its nothing more than a guess, but lower 1 through lower 4 probably represent the binary bits of the least significant digit and upper 1 through upper 4 represent the corresponding bits of the most significant digit of a two-digit hex value that the laser controller interprets.
If you were to post the brand and part number of the laser, someone here might recognize it and point you to a URL where you can get a copy of the user's manual. It would be preferrable to base the design of your interconnection on the information to be found in the manual rather than on my WAG.
You have 256 settings, you also have 256 possible inputs.
255 = 11111111 in binary add 00000000 as another possible input gives you your 256 settings.
again another guess.
Paul
Hi experts, I hope you're all having incredible days. I'd really like to utilize this sensor for a customer application, but the issue is that...
17
18,857
I'm trying to communicate with my keyence laser marker using a Mitsubishi plc Q series over Ethernet. I can open a connection and i can read the...
2,686
Im semi new to plc's. What I am wanting to do is Used a laser distance sensor to control hydraulics on a machine. More or less a stop system...
3,999
Hello, I'm looking to developing a laser barrier system using measuring laser sensors, These lasers will give me either 4-20mA or 0-10V. if...
4,481
Hi Gentlemen, I want to interface a Domino Laser Coder with an SLC 5/04 PLC. I was reading and the coder has RS232, Ethernet, and USB...
3,709
