Plc Trainig Unit
MISURATI
Guest
M
I would like to learen about PLC Could you please show me What is the requirments to use PLC unit for trainig purpose
You will need some knowledge on relay logic concepts, lots of enthusiasm, a PC and a PLC software, preferably with a simulator to simulate your logic, and of course time to browse the internet/ read and understand PLC related forums/ website
Good Luck
Your least expensive alternative is probably going to be AutomationDirect.com. They have a DL-05 unit for arounf $100, $100, and a cable for $30.00. I suggest you add an analog card to explore working with anaolg systems, and that is $80.00.
Other brands have starter kits, although these may be a little more expensive. GE VersaMAx micro and Allen Bradley's Micrologix 1000 are good starters. If you contact your local distributor you can get pricing.
PLC training
Hai Misurati.
Bacically you will need some knoeledge on relay/timer logic.If you are having PC with internet connection,you download the picosoft3.0 free software from the www.ab.com/plclogic/pico web site,and setup your PC.In this software the simulation tool is available,It's very useful for develop your plc program logic knowledge.Try to use it.
Best Wishes,
S Shanmugam.
I have been playing with PLC's for about a year off and on, nothing real serious. I want to get serious with this, My question is where can I get...
3,275
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
89
Hello, I have a Mitsubishi FX3G 14M PLC and a E615 HMI from Mitsubishi/Beijer. I'm using GXWorks 2 to do the programming and I have no problem...
61
Hi, I'm trying to import a Rockwell/AB EDS to Beckhoff but I'm not sure how to import/install the EDS. It is a PowerFlex 525 EDS. Is there a way...
80
I want to communicate my Q series PLC with Factory IO using GX works 2 software, I want to use modbus as server and the ips are as follows plc...
53
