PLC vs PepperL-Fuchs Laser Sensor
We do apx 70 inch wide web at 800 FPM with multiple micro-epsilons. Not sure the OP's actual need, but we don't need the full 70 inch stitched together. Just strategic samples across the width. Coverage of the 70" is probably 50". About 15K worth of hardware, not including an existing CLX.
It is expensive!
Compactlogix 5480! window 10 IOT Enterpise.
Windows 10 IoT Enterprise is a version of Windows 10 that is designed for use on Internet of Things (IoT) devices. It is compatible with the .NET Framework, and you can use it to develop and run .NET applications
In order to do so, the DLL files need to be compiled specifically for ARM chips.
I'd be borrowing one from a rockwell distributor to test before splashing the cash.
Maybe not, looks like rockwell went with Intel, my other searches on that OS only revealed ARM.
Hello, I am a plc engineer and I have a job to do in the NIGERIA 25000 TON GRAIN SILOS STORAGE CONTROL PANEL. A problem where the panel is not...
119
GitHub Link: Open Industry Project This is a side project I've been working on for some time. The goal is to provide an open platform for...
123
Dear All, Currently i'm working with Endress Hauser flowmeter and AB PLC and try to integrate with 2 items. Flow meter spec using is Promass...
167
Can I connect two A-B Panel View 7 to a A-B PLC. Same graphics etc. One on the local control panel and the other Panel View 7 in a remote control...
65
Hello, I'm working with Studio 5000 and ME Station, and I'm trying to find a way to detect if the PC with the HMI is shut down or not. I've tried...
150
