plc
Define what you want it to do first THEN come back and share what you have. We'll help you with your homework, but won't do it for you...
Better have a lot of free time OZEE!
You need to crank out code for "ANY" PLC
Ok , try this logic ( Apologies to basic )
10 Read up as much as you can
20 Study what it is you have been given to do
30 Make an attempt to do most of it yourself
40 go to 10 ( repeat as many times as needed )
50 Provide as much detail as possible
60 Be polite
70 Ask a question that can be understood
End
Kind regards - Mike
Alaric said:
:D :D :D Thats my kind of logic!
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
21
Hello, I have a Mitsubishi FX3G 14M PLC and a E615 HMI from Mitsubishi/Beijer. I'm using GXWorks 2 to do the programming and I have no problem...
53
Hi, I'm trying to import a Rockwell/AB EDS to Beckhoff but I'm not sure how to import/install the EDS. It is a PowerFlex 525 EDS. Is there a way...
75
I want to communicate my Q series PLC with Factory IO using GX works 2 software, I want to use modbus as server and the ips are as follows plc...
50
Hi everyone. I'm trying to read values from a Loadcell with a 2080-TC card. I know the 2080-TC is a thermocouple card but it reads millivolts that...
87
