Dear everybody,
Thank you for your patience and excellent guide. I finally succeeded meeting the first challenge in Analog programming. I managed to configure the I/O cards. When I inject 1-5V into channel 1 of 1771-IFE/C rev 02 input card and using the mov command, the PLC5 is now produce the 4-20mA output from the channel1 of the 1771-OFE2/B rev AB2 output card.
I appreciate if you can guide me step-by-step on how to implement PID control. In my lab I have a simple process loop ie. a dp transmitter is giving out 4-20mA signal (PV) to measure height of a water level in a transparent plastic tank. This current signal is converted into 1-5V by tapping across a 250 ohm resistor. The 1-5V is then injected into a Yokogawa controller. Using a PI control, the controller then gave a 4-20mA output(MV). This output goes to I/P converter to move a control valve. The control valve is at the upstream side of the tank. A pump is used to move the water in the loop.
Now, I wish to replace this Yokogawa controller with my PLC5.
How should I do it - what is the ladder dagram to carry out a P,I,D control; do you need an external 1-5V or 4-20mA signal for SP setting and etc. I knew the basic concept of PID control. Again I appreciate your good guide.
Thank you
