PLC5 ASB module fault
usajrz1
Dec 2019
Indiana
Hello,
I have a remote IO rack communicating back to a plc5-40 processor via DH+ that has recently given me some strange issues. the rack has been in service for probably 15 years with no major problems. starting on 3/1/20 we had an adapter fault out of no where. Module got swapped and almost exactly 12 hours later we had an identical issue. The card we used to replace it was a used spare. the night tech assumed that it was actually a bad spare and replaced it with our last new ASB module. 13 hours after that we got the adapter fault light again. i mostly work on the hardware side but have some very minor programming experience. im at a loss for what could be causing this. Has anybody experienced a similiar issue before?
Faulty spares are absolutely a possibility.
Even brand new in unopened box, electronics age when laying on the shelf for years on end.
In particular electrolytic capacitors are destined to go bad sooner or later.
I have a new project that is replacing the PLC-5/30 CPU with a 1771-ASB and ControlLogix CPU. This line is all blue-hose comms to 5 racks and the...
22
4,923
In preparation to migrate from PLC5 to ControlLogix, we are moving our PLC into a separate chassis, using a 1771-ASB in its place in the former...
2,531
Why does RSLogix5 allow you to choose the 1746-NI8 Class 3 Mode, and insert the correct size BTR/BTW rungs even though this mode appears to be...
1,905
Hello, This is my problem and I expect that you´ll be interested . Actually I have the following network. One PLC5-40 Controller with a...
23
9,856
I use the RIO Scanner of a PLC5/40 to talk with different item on a RIO Network. One of them is a SLC500 Rack (with a 1747-ASB). The SLC500 rack...
5,382
