PLC5-E message read through ENI+Micrologix 1500 ERROR
tx4129
Aug 2007
thaialnd
21
I have made message read at PLC5-E and target device is Micrologix+ENI. the message indicated the error "connection was broken" How to make it works.( both of controllers are in the same network)
Thank you in advance.
You must use the "multi-hop" message type on the PLC-5 to communicate with a 1761-NET-ENI device.
An excellent example of this kind of MSG instruction many be found in RA Knowledgebase Document # 19726.
Your PLC5E must have a minimum firmware level to be able to communicate with the Net-ENI or with ControlLogix:
Series E rev D.1
Series D rev E.1
Series C rev N.1
Series E rev D.1
Series D rev E.1
Series C rev N.1
Ken' Thank you very much ,I follow your method ,it works well.
Thanks again
Hey everyone! I am trying to set up some messaging between two of our older PLC's, having difficulty getting the configuration nailed. I've made...
1,280
When creating a new input on a remote microLogix transmitting to the PLC5 via 9810 MDS Data Interface on Channel 0. Will the data file...
1,415
I have a slc5/05 writing to a plc5/40 processor ( using message), everythings works ok for hours sometimes days then it gives error 37 and stops...
3,474
I'm trying to use a message instruction to read the value from a PLC5/20 into another. I have searched the forum, but am getting more confused...
2,137
Hello,ive got a plc 5 reading data from an slc5/03 40 miles up the river. It is done using two us robotics modems and a pstn telephone line both...
2,758
