PLC5's can talk discrete over DH+ to a DH+ PV correct?
spaceacealpha
Sep 2009
Tennessee
79
Someone installed a RIO PV and I'm wanting to replace it with a DH+ PV (the PLC5 has both ports). I'd rather talk discrete than block transfers plus the same installer made the blocks tiny so there is no room for expansion.
DH+ doesn't need any block transfers at all on Panelviews. The Panelview can directly read the PLC5 data tables. It might not be able to read the actual I: and O: tables directly though, I've forgotten that.
Keep in mind that while the DH+ PanleView can read the Satus on the Input and Output Tables, it isn't going to be able to write to them.
You will have to change the Addresses in PV to B or N and use them in the PLC Program in place of the Inputs and Outputs that you were using before.
Stu.....
I just upgraded a few of my servers to version 10 the upgrade worked fine but for some reason all my short cuts that I linked to PLC 5's will not...
1,606
I am up grading a RIO 1400e terminal that is communicating to a PLC5 with BTW and BTR instructions. They are upgrading to a 7 Plus ethernet...
1,219
I’m having some difficulties getting a new FTVSE network distributed application communicating to a PLC5/40b with an ethernet side card. My...
1,918
I am using factorytalk view studio 7. I am trying to pull data from a plc5/25, from N10:0 to N10:9 and display this data in ascii format. I am...
14,717
Hello, I've looked around here and Allen-Bradley and I can't find exactly what I need. I'm converting an old 1400e to PanelView Plus and I'm a...
3,670
