PLC_Software
Nauris
Jul 2015
Riga
Hi guys.
I am working with lot of machines using PLC and HMI.
Time to time my life would be easier if I can download (make backup) and monitor PLC software, so.
Question- every PLC controller uses his own software, or I can use universal sowtware to do that?
I want to download lader programmas for controllers:
B&R (CP 476)
Omron
Siemens (200/300)
Not only is there not universal software that supports multiple platforms, but the two PLC's from Siemens that you mentioned (200/300) can't even be programmed by the same package.
There is something called codesys which is a programming environment used by a few different vendors, but I think they each customize it to suit their own hardware. It is closer to universal, but you still need to get it from each vendor, and only supports the products that vendors build support for.
Some of the major player are trying to make this better like with studio 500 and TIA portal but there is still a long ways to go.
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
119
I have downloaded COMMGR 1.15 software on my laptop. After downloading it works. When I stop and start the program again it doesn't work. It is...
154
Hi everyone, I have a small project for an industrial site entry gate system. It's running on an old Melsec PLC, and I have a new Shihlin PLC...
138
Hi All, How do I set a password to PLC using Proficy machine software 9.5-9.8 or some other way? I as using Emerson CPE305 CPU. Thanks.
374
Hi everyone id like to start by saying im not a PLC programmer so my technical terminology is limited. i would like advice on what software is...
300
