PLCSim Doesn't Work Properly??
jelcyno
Jan 2006
Cracow
I've got problem with PLCSim. I'm using SFB4 (TON) and this block doesn't make a delay time, it just copying actual input state to the output without any time delay! But in real PLC it works just like it should. Do you know what should I do with my PLCsim to work properly?
best regards...
Hi Jelcyno
I assume that you have STEP7 v5.3x Professional Package and you haven't upgrade your PLCSim? Upgade your PLCSim, put the latest SP and Hotfix version in it -> surprise, surprise it start working.
Hi I used to be able to launch PLCsim without any problem. Now it tells me " STEP 7 Professional Licence is required to simulate this PLC"...
561
Daft question coming up...When I want to modify a value, what's the best/correct way to do this? At the moment, I am entering the value (e.g...
456
Hi, I want to use PLCSIM because the hardware I was working on has now been delivered to customer. Which option do I choose from this drop-down...
379
hi everyone. i hope you guys are doing great. i am trying to built communication between aveva intouch hmi 2023 and tia portal v18. i dont have...
587
Hi, My PLC hardware has been delivered to customer site - many thanks for the invaluable help on this forum! I was looking into see if it's...
2,556
