Plcsim tia v15
userxyz
May 2002
any
2,768
After upgrading my project to V15 I started the simulator... but it gave me a message that my blocks could not be simulated unless they are enabled for Sim ??
In the Compilation tab it checked:
- Can be simulated with SIMATIC S7-PLCSIM (Advanced)
But, greyed, so it enabled it but I cannot change this...
Anyone who has experience with this allready ? :)
Kind regards,
Combo
DB Accessible from OPC UA is enabled... but greyed also. My current project is about an OPC UA link to our PLC... This is an interesting feature, because we can protect all our other DB data if we can disable it on those DB's... But it is also greyed out and cannot be changed, also for this anyone who knows more about this new feature ?
Thanks,
Combo
It would appear that once you have OPC the check box for the DB attribute is checked and cannot be turned off. However, you do have OPC/HMI access settings for each tag in the DB.
Kind regards,
Combo
You need to right click on the project (top of the tree), and in the 2nd tab of the project properties enable the simulation. Then compile rebuild all your PLC.
This is a new "feature" starting in v14 sp1. I have never found any one to explain to me why it is needed/beneficial.
Thank you mk42. I've been wondering about it for two days and couldn't figure out if it was a new feature or something I'm doing wrong. I guess I will contact support and find out why.
With regard to the first post. If you change the device's firmware version to a later version (anything after version 2.0) you will be able to uncheck the option "DB accessible from OPC UA" but you will still have to turn on simulation support in project properties or just click OK when the dialog box pops up. And I believe that not being able to uncheck it in the older firmware meant that it was not available at all ( just a guess).
Also if you have your own standard/library blocks, you need to recompile these as well.
Hi I used to be able to launch PLCsim without any problem. Now it tells me " STEP 7 Professional Licence is required to simulate this PLC"...
547
Hi, I want to use PLCSIM because the hardware I was working on has now been delivered to customer. Which option do I choose from this drop-down...
376
hi everyone. i hope you guys are doing great. i am trying to built communication between aveva intouch hmi 2023 and tia portal v18. i dont have...
579
Hi, My PLC hardware has been delivered to customer site - many thanks for the invaluable help on this forum! I was looking into see if it's...
2,548
Hi Friends, I tried using TIA Portal v17 with S7 PLCSIM Advanced v4.0 but no luck. Has anyone here tried with success?
10,137
