fita Member F Join Date Mar 2009 Location home Posts 17 Jul 24, 2009 #1 Please can anyone convert attached file to .awl format i desperately need it thanks
504bloke Lifetime Supporting Member Join Date Jan 2005 Location Down South Posts 2,721 Jul 24, 2009 #2 see att
fita Member OP F Join Date Mar 2009 Location home Posts 17 Jul 24, 2009 #3 dear dave thanks for the reply.. but it aint working it says opening not correct.. u please check it again i want it in step 7 compatible mode thanks Atif
fita Member OP F Join Date Mar 2009 Location home Posts 17 Jul 24, 2009 #4 dave is it possible that we cut and paste it in step 7 compatible mode or paste it in note pad
504bloke Lifetime Supporting Member Join Date Jan 2005 Location Down South Posts 2,721 Jul 24, 2009 #5 The file you posted was a microwin file and not a Step7 file ? I converted this to awl as requested and it looks fine to me, i suggest the problem is your end with whatever you are opening it with ?!
fita Member OP F Join Date Mar 2009 Location home Posts 17 Jul 27, 2009 #6 thanks for your reply... can u please tell me the version in which i can open this awl file. please give the link where i can download this thanks Atif
rohan tandon Lifetime Supporting Member R Join Date May 2005 Location Dubai Posts 195 Jul 27, 2009 #7 I hope you are using Microwin. Version should not matter as it is an .awl file. You need to 'import' the file and not open it. Select Program block in the program editor and then goto file menu and click import. This should work.
fita Member OP F Join Date Mar 2009 Location home Posts 17 Jul 27, 2009 #8 Thank you all for your help its working!!
