Please help with Digital Transducer
srbmiki
Jan 2015
Sochi
Please,
I need write program in STEP7 on Siemens SIMATIC300 and IM151-8 PN/DP CPU for digital transducer inclinometer, accelerometer, rotation.
Please help.🤞🏻
I am also learning and your issue is I suspect over MY head, (plus I know nothing of Siemens).
BUT, if you state very specifically exactly what the program should do AND, as importantly, what you have done ...so far... and just exactly where you are stuck you're likely to get advice that will help you learn to be able to do it.
Good Luck
Spaseba
Good Luck
Spaseba
Thanks.
The program needs to read data from the sensors in the case of cocoa oscillation of the building. I managed to create a configuration that works but I have a problem to make FC and FB in the STEP7 who will then send the data through the CPU to WinCC.:(
Started my first Scada and controls job this week. I am reviewing drawings for a gas valve automation project. There is three valves to automate...
2,915
please help me . I have to make this ladder diagram and I can’t figure it out :(
410
HOW to communicate with OPTIX and Mitsubishi's Q Series PLC?? PLEASE HELP ME
81
Hello, I am trying to get a Yokogawa Hart pressure Transmitter and a Rosemount Temp Transmitter to read on a 1769-IF4 module on an L33ERM...
399
Please help me, I have solve many week but still not solve it. I found trouble of factory talk studio when I set tag by browse address of OPC...
131
