Pls help on this GE proficy problem.
briana banks
Jul 2005
242
Hi All
i tried to create user defined function block that recive a UDT structure as parameter modify its values and return it. in the way that C language or RSLogix 5000 do, but with no succsess.
How can i do it?
pls help.
One way (and possibly the only way), is to create the UDT structure in the function block "members" area, then access the instance data directly.
Hi im doing a energy saving program for a lamp. And basically the instructions are to turn off the lamp if is not being used ....... but with no...
1,495
[IMG]https://www.img.in.th/image My timer cant run, please help me
3,270
Hi, I am fairly new to PLC programming and in this project i have to understand the electrical circuit and implement the logic in PLC. The only...
1,838
Trying to wrap my head around an Eberle PLS 511 program. I have a register 700 describes as EXOR/ZS/inc.dec counter. Looks like it's called up...
2,109
Hi, I have added digital output expansion module(1762-ob32t) to the PLC and able to program the output but when i try to measure the voltage,i am...
2,995
