PLs let me know what's meant by K
dibu
Feb 2006
Mumbai
Dear friends,
I'm configuring a controller now.. and for thermocouple input of the range -200°C to 900°C the input resolution given in the data sheet is =<0.05K. I'm confused what is this "K"...
Can anyone help me??
A span of 0.05K = a span of 0.05C.
IOW, 1 Kelvin and 1 degree C are the same size - the only difference is Kelvin is defined as 0.0 at absolute 0 while Celsius is defined as 0.1C at the tripple point of water.
A temperature of 0 degrees Kelvin is equal to -273 degrees Celcius
One degree Kelvin is the same as one degree Celcius
So:
- 0 degrees Celcius is 273 degrees Kelvin
- 200 degrees Celcius is 473 degrees Kelvin
- 900 degrees Celcius is 1173 degree Kelvin
Hi im doing a energy saving program for a lamp. And basically the instructions are to turn off the lamp if is not being used ....... but with no...
1,488
Looking to get a program off of an older Eberle Vario P-621 PLC. I don't know much about Eberle, but some quick research brought up the idea of...
1,081
[IMG]https://www.img.in.th/image My timer cant run, please help me
3,264
Hi, I am fairly new to PLC programming and in this project i have to understand the electrical circuit and implement the logic in PLC. The only...
1,832
Hello All I have an older machine that has an existing Electro Cam PLS. I want to look to replace this system and add an encoder to capture the...
2,219
