PNP vs NPN I/O and PLC
R-Phil
Nov 2003
Indiana
39
Please read this article and tell me what you think.
I am a little bit confused on The NPN vs PNP I/O and PLC. Maybe I am reading it wrong but reading this article and also reading the online tutorial on DC Inputs from Phil got me mixed up. I was wondering if I can get a clear explanation on the subject. Can somebody direct me in the right direction (Reading, tutorial, etc).
PNP vs NPN:
PNP can be remembered as Positive Negative Positve
A PNP PLC or I/O requires a Positive or Plus voltage as an Input. A PNP Output pushes out a Positive or Plus voltage.
PNP is the preferred "normal" way to go.
Best Regards
For example, I need to choose PNP sensor for a Sink PLC input. Also do Sinking/Sourcing PLC inputs relay to the PLC reading? e.g. PNP sensor for...
27
19,858
Hello to all, I have a little problem. I have an FP-X C40T panasonic PLC and in the input area i have +24 Vdc. I have NPN optic sensor and I...
14,040
I have been given the task to buy a LG PLC, about 20 I/O, I need to wire some proximity switches up to the inputs, I need to use the inbuilt 24v...
9,402
does anyone know how to convert a pnp signal to a npn? for a plc input.besides using a relay.
31,358
