Point IO and Node-Red
Maxkling
Mar 2011
Atlanta
511
I have a spare 1734-AENT adapter laying around and was wondering if it would be possible to make a connection without a processor, specifically with Node-Red. I installed the package, but I'm getting hung up on tag name. Can you direct address this as an IO adapter?
Point I/O modules exchange data via class 1 implicit connection. These types of connections take place on a repeating specific time interval (RPI). It's data isn't exchanged by "tag name". It is most likely that your node red module makes class 3 explicit connections.
When node-red makes the request, in wireshark, you'll probably see a successful register session, then an attempt at the forward open, but the Point I/O module probably replies with something like "service not supported", or some kind of CIP error.
I'm just taking a guess at this, I've never used this node red module.
Hi All, I have a Devicenet network installed, configured, and working properly. One location in the network consists of the following: 1734-PDN...
4,462
We are having issues with our viewpoint server randomly crashing and only loading the error page if anything at all. It lives on 3 servers all of...
60
Good morning, I have a question regarding some point I/O modules. We use 1734-IE2V modules to measure the tension of a fiber, but we have quite a...
85
Hi, I have some problem with View Point which I'm using to manual control of conveyors. On begin when in network was only PLC and HMI View Point...
100
I have a bunch of tags in Historian/VantagePoint that off by one decimal point. I looked into the HMI displaying the same number, and the HMI is...
136
