Portable Desk/Table
Christoff84
Jun 2006
Cambridge, ON
407
Hey folks, I'm looking for a portable desk/table that can be lugged around a plant for programming needs.
Ideally it would be lighter, and be able to be easily carried up/down stairs or be a desk height with a built in chair. Most everything I can seem to find is table height of ~28 inches, so when you're standing doing work ,it's quite low.
Does anyone have any suggestions or favourites they can share with me?
Thanks,
Chris.
This is what I use...
:whistle:
I have seen tables that attach to the safety rails around the machines. The only problem is that you must stand.
I prefer standing over getting up and down and up and down. Most of the time when I am in the field, I am moving from laptop to machine and back quite frequently.
Now, there have been times when I needed to stay at a machine for many hours and work at the laptop, and when those situations arise, I may move to a sit down position. I need to find a lightweight folding bar stool to go with my table for those times.
https://www.walmart.ca/en/ip/cosco-...ing-activity-table-2-pack-black/6000197067213
This is what I use. I work for an Integrator and I travel a lot. .... But I only gave $12 for it , for some reason it shows $59
Because that seller on Walmart is upping the price and over charging... Walmart.com is like everyone else now and company/people can sell on their website and thats also for two of them
I just stopped selling on there...
Here is the cheaper one https://www.walmart.com/ip/Mainstays-Personal-Table-Black/39131547
Hello, Does anyone know if there is a portable version of RSLinx Lite (even an old one)? I am wondering as I am trying to put together some tools...
688
Looking for recommendations for a small portable WIFI / Wired Hotspot box thing that I can use when travelling, sort of thing that will allow it...
4,913
Hi, Im looking for a solution i can add into the cabinet while commissioning to avoid having guys trip on cables and to have a small amount of...
2,245
Looking for recommendation for a portable clamp on flow meter to check water flow in steel pipes and compare it to other flow meters as a double...
5,063
I was wondering what others may use for a continuous flex cable for ethernet and some power / control signals. My application is for a small...
1,976
