Portal Profinet IO cannot be edited
DamianInRochester
Jan 2011
Rochester NY
1,292
Portal Version 15.1
I have an established device in the Profinet tree.
Device is currently operational.
I need to modify the I and Q addresses on the device, but for some reason it is all greyed out and
Change Device and Start Device Tool are greyed out as well.
Delete is greyed out.
PLC is offline.
I cannot edit any local or distributed IO.
Not sure what I am doing wrong. Any hints?
Portal Version 15.1
PLC is offline.
Double check that it is really offline. Select the project and then hit offline, just to be sure. Sometimes it looks like you're offline, but in the background Portal thinks there's a connection somewhere. And if there is more than one device in the project, make sure you're offline with EVERYTHING.
Not saying its definitely this, but that happens to me multiple times a week.
I have a system with an ET200SP controlling a Profinet network already pre-established. Am I correct in that I can add a Modbus TCP/IP node and...
1,932
Hello all. I have trouble getting online with TIA portal V15.1 with a VIPA CPU(VIPA 315-4PN12). If I try to connect I get an error message that I...
3,393
Hi, I try almost everything but not solve the problem. As attached is the screenshot of the error from Tia Portal, There seem problem with the...
4,124
First time I have used an absolute encoder and it is definitely:banghead:. I have a Siemens 6FX2001-5FN25...
21
6,138
I am tying to find a way to copy 10 words from my input area into a structure I have mapped out for my device. What is the best/simplest way to...
2,178
