Power Quality Meter On Inverter Fed Motor
ian.smith7
Aug 2002
UK
145
Hi All
I Have a power quality meter that I have previously used on A DOL motor as a data logger. I want to do the same on two inverter fed motors. I know the PQ meter will not be accurate because of the PWM content of the drive output but I actually want to compare the two motors.
In this case would the readings be repeatable (ie if they vary with the pwm is it a predictable variation). This would allow a valid comparison of the two motors running through a mix cycle.
Ian smith
Hi Myles
I had not thought of measuring the input to the drive but I suppose input=output x efficency. I will have to try that tommorrow.
At at the moment the energy usage value monitered by the Mixer control system comes out of the Drive control via a RIO link to the PLC. How accurately would the input power to the rectifier track the output power figure from the inverter as provided by the drive control system?
Cheers
ian
i would think the power figure the drive has would be accurate. what ttype of drive is it? there are many specific drive experrts on the forum who could answer that better than I. but how accurate do you need? if it is a comparrison between two motors i would think measuring the input with your meter would give you a pretty good figure.
cheers
myles
Its an Allen Bradley PowerFlex 700. I am also investigating using an OPC server to collect the data into Excel. But the PQ Meter is a lot simpler for me.
ian
Hi all, Client had some power quality issues and we suggested putting a power quality analyzer on the line; PG&E did for three days, said it...
2,330
If I am using a PLC that has a 24 VDC power supply is that enough to provide good power quality or do I need a 120 volt UPS feeding that 24 DC...
3,059
I have a customer who is insisting on using the battery charging system of a diesel engine (24vdc)to power his AB CompactLogix plc. There is a 6"...
2,405
I am trying to find some information such as case studies done on power quality issues with plc's with and without power conditioners. Possibly...
4,513
Hi all, we are an oem manufacturer of a stair routing machine. We have quite a few of the machines running fine except one that we installed about...
3,282
