janner_10 Lifetime Supporting Member J Join Date Dec 2014 Location Tewkesbury Posts 1,301 Nov 27, 2017 #16 In your example, you aren't giving it the start CMD - it wont be moving anywhere without that!
SebasMora Member S Join Date Apr 2017 Location Orlando, FL Posts 2 Nov 30, 2017 #17 Solved this issue. There is a parameter to enable Reverse direction that I was not aware of. This code works as shown as long as my Drive:O.Start is true. Direction is selected by toggling Debug_Bits_SM.31.
duskogavrovski Member D Join Date Aug 2009 Location Windsor Posts 3 Mar 22, 2019 #18 PowerFlex 525 - what will happen if I connect DB resistor to DC+ and DC- instead to BR+ and BR- ?
RonJohn Lifetime Supporting Member Join Date Jul 2013 Location NE Ohio Posts 535 Mar 22, 2019 #19 Welcome to the forum, duskogavrovski! Since this thread is two years old and your question isn't directly related to the OP, I'd suggest you start a new topic to get better results.
rupej Member R Join Date Sep 2014 Location NC Posts 967 Mar 23, 2019 #20 duskogavrovski said: PowerFlex 525 - what will happen if I connect DB resistor to DC+ and DC- instead to BR+ and BR- ? Click to expand... It would become very warm, very quickly.
