Powerflex 70 issues
SBeckley
Sep 2012
Ohio
Trying to download parameters on a Powerflex 70 using 1203-USB cable and I get this message. There are no connection issues. It says the versions are incompatible. So my question is there any way to change the version in the software to match the drive.
They are 2 different versions of the PF70 drive, the std PF70 will not have all the features and parameters that the PF70EC has, I think that there is a conversion tool in DriveExplorer under Tools.
Alan
Thanks,
Ill check that out tonight when I go in. I did find a download for the firmware upgrade through control flash at AB.com I have not tried that yet either.
You will only be able upgrade the firmware like for like. ie you cannot make a PF70 into a PF70EC, it is different hardware for the control boards, althought the power structure if likely to be the same.
Alan
You are correct on the part about converting a 70 to a 70EC.
What I did was went out and uploaded all the parameters of our drives. So I have all these .dno files for each machine. Well I changed a drive last week and have it sitting my office (PFLX70) and I tried to download another drives parameters into (70EC) and it gave me that error message in the picture I posted. I obviously got that because of the drive differences (70 and 70EC). I did not know there were two diffrent powerflex 70 drives.
I tried using drive executive to change the offline parameters for the 70EC into a 70 and was unable.
Correct me if I'm wrong but I believe that we are putting EC's in place of the regular 70's and its allowing us to do that because we are "upgrading" if you will. I guess my question is that situation possible to go from a 70 to a 70EC. This is something I could check myself and probably will but if you know right off the top of your head then your input would be appreciated. :)
Ok I went down to the parts room and grabbed a 70ec and was able to convert the file that was in a 70 to a 70ec and then download that into the ec. My assumption is that you cannot "roll backwards" into an older drive.
Thanks, Samuel
Hello, I am currently in the final week of my internship and I have encountered issues with communication between a PowerFlex 700 variable...
169
Hey I'm setting up a powerflex 755T, but in the connected components wizard during startup, I'm getting an issue where next to the start button it...
252
Hello all, new here. I have 16 Powerflex 40’s that I am converting from DeviceNET to Ethernet. I changed all of the Comm modules to 22-COMM-E and...
1,133
PLC L30ER V30.01 VFD PF 525 V7.0001 Running into an issue that I've never seen before. Ive configured many PF525's before so i know the...
1,236
Hi, I have installed a number of Armor powerflex drives. They are controlled from an L81ES controllogix. DLR is on a ENT2R. I keep getting the...
1,839
