PowerFlex 70 Upload Comm. Problem
kirk_dotson
Jan 2007
majestic
I am tring to upload parameters from a powerflex 70 drive. My goal is to back the files up and place them on our backup server. I can go online with the drive, view and change parameters. When I go to upload all the parameters I get a Comm. Fault in the program. I am using DriveExplorer Lite V5.02 and the serial converter (cant't remember the part #). I have tried on seperate PC's one with a true serial port and one using a USB to serial converter. Below is a pic of the fault I am getting
Kirk, wath kind of cable are you using to communicate the Powerflex drive and the PC or laptop?? Is it an "official" Allen Bradley product (like 1203-USB or Anacanda) or you make the cable yourself??
If you can go online with drive use File-save as- enter drive description or IP. Sounds like you have proper comms if you can connect. Also save a csv file just as a hard copy. This is done by printing as a PDF file under file on tool bar.
Object Class 0x9E is the DPI Configuration class, so the software is failing in something related to the DPI peripherals (the HIM or a comms adapter or the Serial/DPI adapter).
My guess is that if you navigated around the DPI peripherals you would find something that wasn't readable.
The issue probably stems from a drive database file that doesn't match the particular drive perfectly, so I agree that the simplest troubleshooting step is to upgrade to the current release of Drive Explorer.
Hi, I have a Powerflex 700 VC (actually a number of them) all connected via RIO using a 20-COMM-R back to an SLC 5/03. I need to install a...
2,472
Hi, I am having issues with Studio 5000 v32.02 and connecting to a 523 PowerFlex drive via Ethernet. My network consists of a 5380 CompactLogix...
1,868
I am trying to upload the exiting powerflex 40 config file and it would not let me. The only choice I see is create database. However when I press...
1,279
So we replaced a PowerFlex 525 drive with the exact same model. I was told that once it is in and given the old IP address, you can upload the old...
24
14,552
Hello, Recently one of my customers had an Powerflex 753 drive without the Ethernet adapter. Is there an way to connect with the drive with CCW...
1,769
