Powerflex 700 Firmware
stallone
Oct 2010
south africa
172
Hello All,
i am replacing 5 Powerlfex 700 drives, 20Bc015a0aynanco.
I uploaded/saved the parameters from the old drive to the HIM,
now when i go to save to the new drive, i get an error!
Config Code Mismatch, i get an option to abort or continue.
The old drive has firmware version 9.001 and the new one is ver 10.004.
ID the firmware an issue and if so can i change the new drive back to older firmware?
I only have the programs on the old drives and no other backups.
thank you in advance.
Are you replacing them with other Powerflex 700s? Yes, you can change the firmware to an older revison. I just it on 3 Powerflex 755s from rev 14.005 down to rev 13.003.
config code mismatch could just be the rev difference. my example above of downgrading would still throw me an error because the parameters I'm coping after I downgrade are from rev 12 firmware. It still copies the parameters, it just complains.
So what happens if you press continue? Does it reset?
Hello, I am currently in the final week of my internship and I have encountered issues with communication between a PowerFlex 700 variable...
242
I've got a Powerflex 700 that doesn't like to get going in the mornings. This motor will run anywhere from 30 seconds to 5 minutes before it just...
202
Looking for some assistance. I am very familiar with Yaskawa VFDs, but not so much with AB VFDs. I am working on some hardwired AB PowerFlex 700...
160
Can someone with Drive Executive please save me a printout of the parameters for this drive in this file. I'm in a bind and would greatly...
374
Hello all, I was forced to replace a Powerflex 700 to a Powerflex 70 due to what is available. The digital input parameters (361-366) have a...
507
