PowerFlex 700s PID in the inverter
Mar 2012
quangngai
I have a 3-phase motor, with the following parameters: voltage is 200VAC norms, current for 2A, the frequency is 50Hz norms, norms speed is 120 rpm, it is the engine with reduction gear the gear ratio is 1:15, to speed feedback to the controller is set compactlogix L32E, via DeviceNet network, you can help me how to equivalent values ​​of the inverter (internal value) in real value. with datalink 32 bit real, and how to use PID control in inverter to stabilize the motor speedHoàn tác chỉnh sửa.
Hi, I have Powerflex 700s drive which I need to migrated to 755TS, and I have concerns with drive parameters, Is there is way to export and import...
766
Hello, I am having an issue with a PowerFlex 700S. This drive controls a travel motor for an overhead hoist. It is periodically not starting...
994
Using CCW version 11 or 12, downloading parameters to powerflex 700s failed. Unknown DPI error. (From message DPI: 81 00 :: 30.1.5) (Heidenhain...
1,963
Hi, At one of a site a Powerflex 700s II is installed and hooked with a servo motor MPL-B4560F-SJ22AA. it is a soap bar length cutting...
1,557
Hello everyone! I'm doing a project using AB 1769 CompactLogix L32E connects with a Powerflex 700S inverter through DeviceNet. After using 1769...
2,980
