Powerflex 753 and DeviceLogix
pauly
May 2002
South Wales,U.k
244
I am having a problem opening the DeviceLogix editor from Drive Explorer. When I try I get the following message:"Failed to create Interface to DeviceLogix Editor!" Has any body had the same problem? If so what am I doing wrong? I am using the USB converter to the DPI port
Excerpt from AB technote 450506 (access Everyone):
"It means that another PC is connected to your drive and has the DeviceLogix editor open and animating.
Only one PC at a time is allowed to run DeviceLogix on a drive."
This doesn't make any sense
Yeah thanks for the reply, I saw this on the Rockwell forum. I am not sure what this means. I only have my laptop connected to the drive.
Ah. Sorry! I haven't used the software myself. I'll look around a bit more and if I see something else I'll post it here for you.
Check to see if your drive firmware and your version of drive executive is compatible. Make this check on the AB website.
I have had version and firmware issues similar to that on 750 series drives.
Good Morning , I have a CompactLogix L33 and several Powerflex 753 Drives ( Ethernet ). In my RS Logix 5000 Tree I have all the drives. In...
2,070
I have a PowerFlex 753 drive connected to my laptop via a 1203-USB adapter. When I connect to this with CCW and try to upload from the drive, the...
5,603
How to remove faceplate from power flex 753 and not shutting the system down. What parameters should i change?
116
Hi all, I am having a problem with a powerflex 753 we have on site and keep getting input phase loss. The drive has been running for a long...
1,385
Hello Friends, We have a powerflex that stopped working sometime last week. It doesn't communicate over the network, or use CCW directly from my...
466
