powerflex 753 faults 4,17
greggerrior
Sep 2015
nova scotia
hey everyone,
I keep getting fault 17 input phase loss anytime the speed of the drive is turned up over 80%. the motor is driving a shaking feeder, the base of the motor is on a spring for this application. motor fame has been tightened as well as the spring. the hopper was cleaned out today as well and ran fine for day shift. this evening we started getting fault 17 again and once we got fault 4 under voltage. just set up our data logger in the mcc that feeds the drive but connections were checked on day shift during scheduled shutdown. Wondering if anyone has had similar issues before. I'm wondering if the dc bus capacitor is starting to fail. in the past they have had this issue i was told it was the motor fame and spring were loose but they were not getting fault 4 as well. if theres anymore information needed i can do my best to get that.
Any help would be greatly appreciated,
Thanks Greg
How to remove faceplate from power flex 753 and not shutting the system down. What parameters should i change?
109
Hi all, I am having a problem with a powerflex 753 we have on site and keep getting input phase loss. The drive has been running for a long...
1,366
Hello Friends, We have a powerflex that stopped working sometime last week. It doesn't communicate over the network, or use CCW directly from my...
458
Hello all! I am fairly new to the world of PLC's and this forum, so I apologize for my lack of knowledge. I have a Powerflex 753 that keeps...
565
I am bench testing a PF753 (20f11nd096aa0nnnnn). I replaced the IGBT's and IC's in the firing circuit. Upon power up, I get the STS light...
724
