Powerflex 755 Tag Question
_Dock_
Sep 2015
KY
508
I cant seem to find an answer in any manual so maybe you all can help.
What is the difference between these two input tags on a PF 755? On a PF 525 you do not have a running tag, only an active tag...
:I.DriveStatus_Active
And
:I.DriveStatus_Running
Thanks in advance
Pg 159 &156 of 750-pm001 give the definitions. Drive active mean the drive is actively moudating an output. Driving running has more requirements, "This bit indicates that the drive has successfully responded to a start signal. The “Active” (Bit 1) status bit will also be set at the same time as the Running status. The “Running” bit will remain set while the drive’s control loops are active and during a controlled stop. The “Running” bit will be clear due to any of the following conditions: drive stopped, drive coast stop, drive jogging, drive autotuning."
So I have a sort of unique situation where I'm wanting to run a PF755 from the IO and over ethernet. Of course, this comes with it's own set of...
313
Hi I was wondering I need to update the firmware of a 755 inverter does the drive hold the program on the drive and just updates the firmware or...
192
So I'm replacing a terminal block on the inverter board for a 755. I'm wondering if anyone knows what conformal coating would be best? I'm not...
151
Powerflex 755, running 2 weeks, and faulting with code 17 input phase loss.
237
Hi All, This is my first PowerFlex 755 drive setup and I am having an issue with when I start the drive it runs at my minimum speed 5Hz, but...
452
