PowerFlex Comm Issues
edward.chiem
Aug 2016
San Diego
There are multiple drives connected to this PLC and all are operational but I can no longer connect to them remotely. I can only connect to 2-3 out of the 15+. (Either through RSLogix 5000 or DriveExecutive) PowerFlex 70 or PowerFlex 4 throughout and all 20-COMM-E parameters were verified.
All the drives are working and being controlled through the 20-COMM-E. PLC is a 1756-L73
RSLinx registers the drives in question as an Unrecognized device. Proper EDS files are installed. See below for the driver diagnostics.
08/10/16 09:16:56 10.15.80.163 Attempting first connection, protocol = CSPv4
08/10/16 09:16:57 10.15.80.163 Unable to establish TCP connection to the Ethernet Interface
08/10/16 09:16:57 10.15.80.163 [10061] Connection refused
08/10/16 09:16:57 10.15.80.163 Device refused a CSPv4 connection, retry using EtherNet/IP
08/10/16 09:17:07 10.15.80.163 Attempting first connection, protocol = EtherNet/IP
08/10/16 09:17:28 10.15.80.163 Unable to establish TCP connection to the Ethernet Interface
08/10/16 09:17:28 10.15.80.163 [10060] Connection timed out
08/10/16 09:17:28 10.15.80.163 EtherNet/IP connection lost; timed out on socket write
08/10/16 09:17:28 10.15.80.163 Device refused an EtherNet/IP connection, retry using CSPv4
08/10/16 09:17:38 10.15.80.163 Attempting first connection, protocol = CSPv4
08/10/16 09:17:39 10.15.80.163 Unable to establish TCP connection to the Ethernet Interface
08/10/16 09:17:39 10.15.80.163 [10061] Connection refused
08/10/16 09:17:39 10.15.80.163 Device refused a CSPv4 connection, retry using EtherNet/IP
08/10/16 09:17:49 10.15.80.163 Attempting first connection, protocol = EtherNet/IP
08/10/16 09:18:10 10.15.80.163 Unable to establish TCP connection to the Ethernet Interface
08/10/16 09:18:10 10.15.80.163 [10060] Connection timed out
08/10/16 09:18:10 10.15.80.163 EtherNet/IP connection lost; timed out on socket write
08/10/16 09:18:10 10.15.80.163 Device refused an EtherNet/IP connection, retry using CSPv4
08/10/16 09:18:20 10.15.80.163 Attempting first connection, protocol = CSPv4
08/10/16 09:18:21 10.15.80.163 Unable to establish TCP connection to the Ethernet Interface
08/10/16 09:18:21 10.15.80.163 [10061] Connection refused
Any thoughts would be appreciated.
Thank you!
Hello all, new here. I have 16 Powerflex 40’s that I am converting from DeviceNET to Ethernet. I changed all of the Comm modules to 22-COMM-E and...
1,130
I had to replace 3 PowerFlex 40 multi-drives that each had 3 PF4M daisy chained off the DSI port. The PF40s had comm-e cards installed for...
2,446
Hello all. Been reading for a long time, 1st real post. AB was unable to help me beyond "Yeah, that's old, we think you should upgrade..." which...
2,395
Bear with me for a moment. So an issue came up this morning, one of our pumps wasn't running. I plug into the processor (5069 ver 31), the...
4,036
I have a Powerflex 70 that periodically returns an Error 85 - Port 5 DPI Loss. I have looked through the AB Knowledgebase and they mainly talk...
3,332
