Powerflex ....... firmware upgrade ?
Karim Halawa
Feb 2016
USA
consider the running drive version 1.1 and replaced it by another one 1.4 ( written on drive itself ) .
This mean i need to upgrade the firmware for the 1.4 drive to 1.1 or 1.4 ?
Hi and welcome to the Forum!
For clarity please provide the complete PowerFlex drive catalog number and what controller, if any, is controlling it.
If you are using a Logix 5000 controller...
When replacing a drive, you can drop in a newer firmware revision drive and either change the revision under the drive module properties or set Compatible Module for Electronic Keying. If you want or need Exact Match Electronic Keying and the new revision is not listed, then you may need to download and install the latest Add On Profile (AOP) for the drive, available from Rockwell Automation.
Regards,
George
Hi I was wondering I need to update the firmware of a 755 inverter does the drive hold the program on the drive and just updates the firmware or...
197
I have a Powerfelx 525 drive that I need to change. It is connected to an L33er processor. The old drive has rev 5.001 and the new drive has rev...
1,045
Quick one. Can a newer 525 control module be swapped in place of one with lower fw rev? Originals are 5 and new 8 but it doesn't work due to...
3,803
Hello All, i am replacing 5 Powerlfex 700 drives, 20Bc015a0aynanco. I uploaded/saved the parameters from the old drive to the HIM, now when...
1,522
Hi, I have been trying to update the firmware on a PowerFlex 755 using ControlFlash plus, however, when I try to initiate the flashing I get a...
2,975
