PowerFlex700 control
angi
Jan 2010
us
361
Hi guys
I need to control a PF700 using CompactLogix(1769-L32E), 1769-SDN and 20-Comm Adapter. my question is how to configure the Logic Command Word and Status Word, what is the address for them in the PLC?
Hi guys
That will depend on where you map them in the SDN Scanner. You will need RSNetworx for DeviceNet to set it all up. Appendix D of the 20-COMM-D Manual has the Command and Status Word Definitions.
http://literature.rockwellautomation.com/idc/groups/literature/documents/um/20comm-um002_-en-p.pdf
Stu....
Hi friends. I am working on PF700, and drive is showing at speed no faults but when I am hooking up the motor, motor doesnt starts and only shows...
1,737
I want to connect my PLC 5/40 to my Powerflex 700 trough RIO remote I/O. I am connected to the PLC trough a 1. How is the wiring in the Remote...
1,281
We have a Power Flex 700 VFD installed which in turn gives power supply to 55 kw motor. Once the VFD tripped due to over heating of vfd. We...
10,144
Hello, I used the powerflex 700 driver,the driver via 20-comm-e with PLC (1769-L32E) communication,I use the rslogix5000 software config the...
2,973
Please help/advice, On Powerflex 700VC with DeviceNet communication card, the drive is off by 15 rpm at 500 RPM, at 100 RPM the actual speed is...
1,267
