pqw value monitoring
Amr Hassan
May 2005
340
hi
is it possible to monitor the value of the pqw?
i was trying to write a value to analogue output chanel to test it. I did not notice i was writing an other value in a differnt statement
the result that the value of the output was fluctuating and i though that i have noise problems,,,,
is there a way to monitor the pqw ?
i tried in the vat , in the hardware configuration and tried to
load the value into another word , all methods failed
I set up a monitor DB where every time I write to a PQW address I also write it to the monitor DB. Depending on your PQW address and memory space, you could make the DBW address match the PQW address for ease of use.
e.g.
T PQW 700
T DB99.DBW700
(NB: To reduce the chance of typos, you could write a little function that you pass the PQW address as a pointer and then use indirect addressing to index into the monitor DB)
Have you tried a VAT table then Variable > Enable Peripheral Outputs
You have to be in stop mode but it should work for testing.
Hello all, I'm hoping someone out there can help me. I have 2 plcs where I work which communicate with each other. In one of them it transfers...
5,049
Hello, I have a CPU 315-2dp plc using for profibus communication with the SEW Movidrive MDX61B inverter. In the hardware configuration I have...
25
8,114
Hi all, I recently was trying to find the addresses being used by a DP/DP Coupler in S7. The addressing was Input Word 20 and Output Word 20...
7,441
It's a simple problem but I can't solve it, and it's starting to **** me. In STL i can load PIW752 in acc1 but i can't load PQW752... Help pls...
2,104
Someone knows a way to move a big range of piw to a DB? The range is 224 byte. We can change the Hardware of the PLC so we can access it with IW...
2,616
