Precix CNC Router with Syntec Controller - Error 75
rkg3d
Oct 2016
BC
Hello everyone...just joined and I'm hoping someone can help me out with the following:
We have a Precix CNC Router with Syntec Controller (with Delta components).
It the past couple of months we've had to replace 2 faulty cables so I'm guessing my current problem could be yet another faulty cable....but I thought I'd try here first.
When trying to do a tool change the machine returns the current tool to its saddle...no problem....BUT, when it goes to the new tool and clamps onto it we get the following error:
PLC 075 No. 75 Spindle Tool Clamping Failure
The strange thing is, when I back the new tool away from the saddle it is clamped in place. It does not fall out. So I'm not sure why it's saying it's a clamping failure.
Any ideas or suggestions?
In the mean time I'm doing tool changes manually which is really cutting into production time.
Ryan
In case this happens to anyone else...
I discovered it was a faulty cable.
When I pressed the tool clamping button the 2 correct LEDs inside the controller went on and off.
When I positioned the head over the tool holder and pressed the button...3 LEDs went on and off.
When I positioned the head approx. mid-way down the table and pressed the button, nothing happened.
I then grabbed the cable chain and moved it up and down...as I did this the tool clamp went on and off erratically...so it must be a faulty cable.
I have a CNC cutting equipment, all the components are Fanuc from the CNC CPU A02B-0307-B822, a PLC AIF01A and a panel i, on the panel i (operator...
133
I'm looking at building an XY CNC, mainly as a learning exercise. I have a spare Beckhoff CX8090, which is TwinCat 2 only. There are some TwinCat...
1,932
We have some large horizontal machining centers for drilling castings. They have custom built hydraulic clamps in the stations. We've had issues...
34
14,327
Has anyone had any experience with this. Have a meeting next week with a vendor and trying to find out more info on my own. Just dont fully rely...
1,337
has anyone ever had experience with the Omron CNC controller controls? According to brochure suppose to be able to execute Gcode commands to...
1,670
