Pressure Control
edward.ortiz
Jun 2015
Houston
28
Hello, I am working with a Siemens 1200 PLC. I have two pressure transmitters that I am reading in the PLC, as well temperature of tank A and tank B. I am trying to figure out the logic to control the pressure of tank A and tank B. As the pressure deviation changes the heater for each respective side will increase or decrease the temperature to compensate for the pressure change until the pressures are balanced. For example, if side A pressure starts to decrease, the side A heater will decrease the fluid temperature, thereby increasing the pressure until it is within 100psi of side B pressure. Let me know if you need any more information so you could help me with this problem. Thank you in advance.
If I read you right, you are trying to control pressure by heating or cooling a material. If so, this must be a slow system...
Also, you mention decreasing fluid temperature will increase pressure? I'm confused by this but maybe I don't understand fully what is going on. Generally when you heat something up, the pressure goes up as well.
it sounds like an assignement, and you will need a table of temperatures and pressures of the liquids.
100 psi is a lot
Hi All, I could do with some advice on a hydraulic control system. It is necessary for me to accurately position a vertical hydraulic ram with...
34
1,966
Hi I am a beginner and therefore have problems with M221 PLC programming. I want to program the PLC so that the pressure increases slowly (I...
2,260
Hello all, I am new to pid loops and control. I was wondering how to control a system with two process variables. This is a water system with a...
2,040
I want to share a trick and see if anyone can do better! With hydraulic presses there is a point at the beginning of the actuator movement when...
3,982
I will have to start up frequency controlled pump that has pressure feedback. In the prepared plc program a pi-controller that has a pressure...
5,001
