Print labels from RSView32
rezalahiji
Aug 2015
columbus
Hi experts,
I am new in in RSView and start to learning, Anyway, I want to create bar-code in RSView and send it to zebra printer via network. Can I do with VB Scripts or I do in need any other application? I need your help to make this happen.
Your kind help will be highly appreciated! Thank you.
rezalahiji,
Which zebra model?
What is the barcode format? code 25, 39, 95, 128, pdf417?
Is this barcode the same on all labels or are they different?
Where is the data for the barcode coming from?
What is the print trigger?
I am currently working with 2 different zebra printer models now
on projects.
regards,
james
rezalahiji,
Which zebra model?
on projects.
regards,
james
Zebra ZT41.
Bar code format is 39.
They are different, I want to create bar code each time.
The data is from RSView.
Print trigger is RSView.
Thank you.
I am relatively new to using plc and have fairly limited experience with them and with programming but have been reasonably successful thus far in...
2,531
Will someone please convert this logic to pdf?
144
Anyone have access to Melsec Medoc plus 2.31a that can either open a file (.pcd zipped in link below) and send a PDF/screenshot of the ladder, or...
388
I am working on a Markem X40 printer which uses NGPCL Commands and needs to send commands using a .net program. I need help with the following...
156
Hello, this is my first post after being a long time creeper on this forum. I am experiencing a fatal error any time I attempt to print to PDF...
400
