Printer selection for PLC DL-06
e_pramod
Feb 2005
29
Hello I would like to print a some value On printer using automation direct PLC DL-06, Which printer i should select Sserial port or Parallel port printer.
Just like most PLC's the DL-06 has no parallel port. It does have a serial port capable of a very flexible 'PRINT' command. The resultant communication could be sent directly to a serial printer or through a serial-parallel convertor to a parallel printer. Obviously the serial printer means one less piece of hardware to deal with.
Has anyone installed Hp laserjet pro 4203 to OMNI 3000 or 6000 via ethernet..Is there a specific Config? I have a problem..Please advise
63
I'm a Manufacturing Engineer with limited PLC experience and I am doing some research for our Controls Department. Does anyone have experience...
191
Hello ! I am trying to use an omron cj2m-cpu33 with a CP1W-CIF01 plug in serial connector to talk to a zebra ZT610 printer. I am getting the data...
391
Shot in the dark here, but a customer has this Arca Linerplus Advanced 4.0 printer/applicator for pallet-tagging and we need to change the mode on...
136
Hi All, I currently have an issue to establish connection between my PLC to Zebra Printer. On my side don't have the ASCII card Module to use...
785
