Pro-Set 200
WireGuy1950
Jun 2005
Fairport Harbor, Ohio
155
Our company just acquired a bunch of presses which contain AB SLC 5/04P processors running Pro-Set 200 programs.
My problem is the disks that were with the machines and obviously the uploaded program contain NO comments. The information from AB shows that the source file does have comments and labels.
Does anyone have access to this program and would be willing to export the label files for me? I'd really appreciate it.
I installed this on a injection molding machine a few years ago for a customer - I will check my archives Monday and see if I still have a copy.
Seeing as a disc came with the presses
Just a suggestion, Go to the Project tree, and look under Database, Address / Symbols and see if you have any comments you should at least see Status descriptions.
My thoughts being that they may be turned off in the ladder properties
Sent you a PM a couple of days ago - I have an original copy of the program - let me know your email address and I will send the original program to you
Evan
I have a Pro Set 700 HMI that died. I have , what I believe to be, is a full backup of the hard drive that I'm trying to run off a MS DOS VM...
1,341
My base address all work fine. The problem starts when I set the Index from 0 to an offset. I get a "PLC No Response" error. So say my Base...
1,177
I am doing something no one else has ever done.... I want a screen that lists all the faults that have occurred in the resent past on one screen...
6,623
OK Gang, I'm setting up a M340 system using Wonderware as the HMI and I really want my DASMB server to match the addressing in the PLC and not be...
2,202
Hello there, I am trying to figure out what resets my daily totalizers in Unity Pro. I need to change it from restarting at 7am to resetting at...
4,460
